350 Ram Jet Engine - NCRS Discussion Boards
350 Ram Jet Engine
  • Gerald A.
    • April 30, 1997
    • 45
    350 Ram Jet Engine
    Re: 350 Ram Jet Engine
    Originally posted by Gerald Avery (29089)
    Has anyone installed the Ram Jet 350 in a mid year Corvette. Purchased the engine, came with 14” externally balanced flywheel. Trying to use my Muncie 4 speed, but flywheel is too dig. Any help would de appreciated
    Gerald------
    You could use the 14" flywheel if you also use an 11" clutch and a bellhousing designed for use with a 14" flywheel (e.g. GM #3899621).
    Otherwise, you can switch to an externally balanced 12-3/4" flywheel. The standard weight version is GM #14088650.
    By the way, all Gen I small blocks equipped with a 1 piece seal type crankshaft such as your RamJet 350 use an externally balanced flywheel or flexplate.
    • Michael G.
      • November 12, 2008
      • 2155
      A bit off topic, but does the plenum on a Ram Jet motor fit under a stock small block hood?
      • Dave S.
        • August 31, 1992
        • 2918
        Yes it will. The midyear FI plenum is about 8" above the base plate and the Ramjet plenum is 8" as well.
        • Mike T.
          • January 1, 1992
          • 568
          Fits fine in my friends 63 SWC.
          Mike T - Prescott AZ
          Mike T. - Prescott AZ.
