Hi All,
Tom K is back and looking for still more advice. I am really grateful for all the help so far. Having an authoritative source of info is the absolute best!
This time I'm in the midst of restoring my 1973 Corvette steering coupler. The AIM only lists a P/N for the upper flange on the steering shaft - I guess since the rest of the joint was supplied to the assembly plant as part of the steering box assembly. I did a lot of digging through the NCRS archives and found a P/N of 7818568 for the service replacement steering coupler assembly. I looked online and found an NOS coupler, but I imagine it will be really expensive (the ad said 'call for price'
) and most likely not an exact replacement. Can someone confirm that 7818568 P/N for a 1973?
Anyway, my preference is to purchase and / or make the correct parts to restore the original rag joint correctly. So...
I removed the original shoulder bolts and rivets. The rag is toast as it has broken at one of the bolt holes. I bought a Borgeson rebuild kit and the rag appears pretty good, it does have seven layers - the hardware is not worth using for a restoration, and from what I have read on the forums here the hardware may not even be safe. Also, the Borgeson rag does not have the grounding screen. My thoughts are to get all high-tech with some wire cloth and a wooden fixture that I can drill through to make the holes and then turn the OD to get the overall size right. When I look closely at my original rag joint, the wire screen does not seem to have been molded into the rubber - is that true? My thought is if it was molded on, how did they insure there would be steel exposed to complete the ground? It seems like even an adhesive might have interfered with the electrical function - any thoughts on how to attach the wire mesh piece to the Borgeson rag, or should I just assemble it under the bolts and rivets?
In my search through the NCRS archives I found drawings of the C2 steering coupler shoulder screws, but nothing on the C3 screws, so I think I will just re-plate mine. I'm wondering how close zinc plating will match the original cad plating? The copper plating should be easy enough there were several threads here with some hints and I'm pretty sure I can figure it out.
Of course I ground the heads off the rivets and knocked them out of the joint so they need to be replaced or re-made. I cannot yet find a source for the proper rivets, but I have access to a lathe and will make up a couple - unless someone knows of a source???
For dimensions of the rivets, I can measure what I've got to get most of the dimensions, except the length of the part that is peened over. I measured the upset part of the rivet heads before grinding and I will make up a tool to get the same size and shape when the new ones are heated up and peened. I am assuming the rivets would have originally been made from a low carbon steel like 1045 without any heat treatment - can someone confirm? Can someone provide the length of the rivets past the shoulder? I should be able to figure it out if necessary through trail and error - I'm pretty good at errors! But hopefully, I learn from them...
My capture strap is pretty rusty, but again I'm thinking If I sandblast and re-plate it in zinc it should be ok. The stamped bowtie shaped center thingie looks like it will clean up ok and be re-plated too. I did find the pinch bolts online, so I will buy those.
One last thing - I noticed one of the rivets is worn where it was rubbing on the upper flange, there must have been a fairly large mis-alignment between the steering box input and the steering shaft. I don't know how to prevent this after I restore the coupling - any ideas there would be appreciated too.
Has anyone gone this route to restore their original rag joint?
Am I just way over-thinking this?
Again, I really appreciate the knowledge you guys have and your willingness to help with my project
Tom Krause
) and most likely not an exact replacement. Can someone confirm that 7818568 P/N for a 1973?Anyway, my preference is to purchase and / or make the correct parts to restore the original rag joint correctly. So...
Tom Krause
