What is the correct flywheel (flexplate) diameter and number teeth for a 67 427 with Auto trans?
Is there a part number? Is the 117365 the correct starter, without aluminum nose, for the required flexplate?
If not what is the correct starter number and configuration/
Thank You
Thank You
