1963 exhaust center hanger - NCRS Discussion Boards
  • Mark P.
    • December 14, 2018
    • 3
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 1963 exhaust center hanger
    I can't answer your question regarding the dimension of the bolts but the automatic transmission has a 2" exhaust system on 250 and 300 HP engines. A 250 HP engine with a 4 speed will also have a 2" exhaust but the 300, 340, and 360 all use a 2 1/2" exhaust system with a 4 speed transmission so the hanger is different for the different applications but the location of the bolts should be the same. I have an older reproduction hanger on my 4 speed car and had no fitment issues.
    • Mark P.
      • December 14, 2018
      • 3
      • David L.
        • July 31, 1980
        • 3310
        Mark,
        Back in the very late 1980's I bought a reproduction 63 Corvette exhaust pipe hanger from a Corvette vendor for about $100. What I matched it up to where it mounts on my 63 frame it was too short. The location where the 2 U-bolts on the bracket did not line up with the 2 holes in my 63 frame. I got my money back the next time that I went to Corvette Carlisle. No comments by the vendor.
        I just asked a question to someone selling an original 63 bracket on Ebay and the answer was 14 7/8" end to end.
        Dave
        • Mark P.
          • December 14, 2018
          • 3
            • 11608
            Does the AIM show different hangers for an automatic transmission car? One would suspect the answer may be in there.
              Originally posted by Mark Plummer (65433)
              It’s probably the same guy I asked and he confirmed that measurement 6 3/8 center to center for the mounting bolts, the ones on the rubber to frame, was correct for my automatic, but at $ 479.00 for my Driver I can’t justify spending that.
              I ordered one again from Ecklers and just cut it in the middle of the bracket and welded in 3/4” and it lines up perfect.
              BUT what I’m trying to find out is there a different one for automatic cars. I would think that there would me an expert/Judge on here that would have the real answer.
              Mark------
              For your 250 HP application, the support/clamp assembly was the same for manual or automatic transmission. It was GM #3828187 and was discontinued without supersession in January, 1973.
