In the process of resolving other issues, I discovered an oil leak, which, I think, was from the oil line to elbow connection. There is no sign of oil within the gauge assembly, but it is not at all obvious why there was a leak. The fitting was tight.
I'm going to replace the line with the original style line, and my questions:
Thank you!
- should I put some sealant on the fitting. If so, suggestions?
- Other suggestion/s
Thank you!
