I have a 67 A/C Roadster and it has power windows, but I don't think they are factory. The reasons I believe this is that A31 is not listed on my tank sticker, there is no relay installed, and the red power wire of the existing harness is plugged directly into the lower fuse block plug labeled "Power Windows" instead of the correct ACC plug as was done in 1967. Thus the windows operate with no ignition key turned on.
I would like make my car correct and replace the existing wiring harness with the correct harness that includes the relay and the piggyback plug to the radio capacitor lead as specified in the AIM.
Can the power window wiring harness be replaced without removing or pulling out the instrument console? What about the glove box? Mainly I would like to know what is the minimum disassembly of dash components (e.g. glove box) necessary in order to properly replace the PW wiring harness? I understand I need to remove door panels to get to the regulators, but what about the dash area?
