1965 SB Top Ignition Shield Front Ground Clip - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2640
    Still working my way through the '65 TIMJG pre-judging my '65 SB coupe. The top ignition shield front ground clip is broke off and I have a second design replacement from LIC to install. Reading through the page 141 it states that the ground clip is held in place with two rivets and two backing washers. My car is a late July built car and should have the second design ground clip that looks like a fishing hook not the first design "T" clip. My original top ignition shield front ground clip does not have the backing washers on the inside as described on page 141. Points are points, so do I install the replacement ground clip with or without the backing washers? As people have stated don't go changing an original car just because the book differs from what is installed.
    James West
  • David L.
    • July 31, 1980
    • 3310
    Re: 1965 SB Top Ignition Shield Front Ground Clip
    James,
    I have a NOS ground clip. If interested, send me a PM.
    Dave
    • James W.
      • December 1, 1990
      • 2640
      So I am asking once again, will someone with an original, late production 1965 Corvette equipped with an L79 or L76 engine send me a picture of the top ignition shielding inside mounting attachment of the front ground clip? I need to know if your ground clip rivets have washers under them. My original '65's does not.
      James West
      • Alan D.
        • January 1, 2005
        • 2027
        Jim,
        Is this what your shield looks like? If so here are the rivets & washers
        • James W.
          • December 1, 1990
          • 2640
          Alan,
          This is mine, looks identical to yours except for the lack of rivet backing washers on the inside.
          James
          Originally posted by Alan Drake (43261)
          Jim,
