I was excited to receive the new '58 to '60 Judging Guide/Technical Information Manual and started to go through it right away. When I got to the mechanical section, I was taken aback by a paragraph that states that Flint blocks can be distinguished from a Tonawanda block by a square plug in the front of the block inboard of the stamp pad. This was the first time that I had heard this as I had been using the old JG/TIM as a restoration guide for over a decade and this was not mentioned previously. So, I went out to the garage and saw that my block has a hex head screw in this position vs. a square plug which gave me a scare as a wrong block is a BIG 350 point deduction. I thought that I had been meticulous in my restoration by ensuring that I had a correct block. Next, I got out the mirror to double-check the casting date which is "L129". According to the new JG/TIM then, I have a Flint block as the Tonawanda blocks had two year numbers. So, my question is: will I receive a point deduction because I have a hex head plug vs. a square head plug? Should I attempt to find a square head plug and replace the hex head one?
