The starter bolts for 63 and 64-67 Corvettes are listed in the assembly manuals and vintage parts catalogs as follows:
63 long bolt: GM # 3815338, 3/8"-16 X 4 21/32"
63 short bolt: GM # 3795470, 3/8"-16 X 1 5/16 with uses Sp. Washer # 3765135 (13/32" I.D. X 11/16" O.D. X 3/32" thick)
64-67 long bolt: GM # 3830134, 3/8"-16 X 4 21/32"
64-E65 short bolt: GM # 3849418, 3/8"-16 X 1 27/32"
L65-67 short bolt: GM # 3880880, 3/8"-16 X 1 27/32"
GM # 3815338 was replaced by GM # 3830134 in Oct. 1963 as per Chevrolet Parts History (service parts).
GM # 3795470 was replaced by GM # 3830135 in Oct. 1963 as per Chevrolet Parts History (service parts).
GM # 3830135 does not appear in the 63-67 assembly manuals.
GM # 3849418 was replaced by GM # 3880880 in 3/31/65 as per 1965 AIM and Chevrolet Parts History (service parts).
Attached below in the photos are 65-67 Grade 8 starter bolts on the left with "RBW" on the long bolt and "C" on the short bolt. On the right side are two Grade 5 starter bolts with "M" on both bolts that match the lengths of the 65-67 bolts. I believe that the long "M" bolt might be a 63 long bolt, GM # 3815338, but the short "M" bolt might be GM # 3849418 as it is 17/32" (0.53") longer that a 63 short bolt.
Question: Were the 63 starter bolts (GM # 3815338 & 3795470) and the 64 starter bolt (GM # 3849418) grade 5?
The 65-67 starter bolts (GM # 3830134 & 3880880) seem all to be grade 8. I have several sets of these grade 8 starter bolts marked "RBW" and "C" from 65-67 Chevrolets in salvage yards.
Dave
Dave
