I was recently asked about the best way to open a stuck hood on a C3 and I don't really have a good answer. Any proven techniques to pop open a stuck hood on a C3???
Opening a stuck hood
Re: Opening a stuck hood
Arland:
Which side .......or both?? For C2 cars a couple of guys developed techniques for both AC and non-AC cars. I believe they made it into the Restorer. Some of theseideas may apply. For the AC car. a special (but simple) tool was developed and used.
What year C3??
Larry- Top
I saw this TSB on eBay yesterday... here are some images, and I made a PDF for you to download.
Hope this helpz,
Jack
Hood Release 1968-1971 Corvette TSB.pdfAttached Files- Hood Release 1968-1971 Corvette TSB-01.jpg (33.5 KB, 335 views)
- Top
Arland
I am not sure if this works up to 1980, but consider it:
To access driver's side remove the splash pan behind the front driver's wheel. With car in the air as much as possible insert a long screw driver or pry bar into opening and attempt to press on the hood latch toward the rear of the car. If the cable is connected from the driver's side to the passenger side this should open both hood latches.
Fortunately I haven't had the opportunity to try this, but I am told it does work.Terry- Top
Terry,
I can confirm that it does work. This winter the pull cable finally gave up and broke. That is exactly how I opened the hood on my 69.
Jeff- Top
