72 BB Fan Shroud Seals, which is which? - NCRS Discussion Boards
  • Michael G.
    Infrequent User
    • April 1, 2001
    • 13
    The upper and lower repro fan shroud foam seals for a '72 LS5 copper radiator look to be the same size. Only difference is one has the adhesive on the wide side, and the other has the adhesive on the narrower side.
    Which one goes on top and which one goes on the bottom??? Note these are not the radiator to frame seals but the seals between the fan shroud and radiator.
    Thanks!!!
