1994 Corvette Power Antenna Relay - NCRS Discussion Boards
  • Jim P.
    • February 25, 2010
    • 58
    Hi I have a 94 Convertible base model. I am trying to trouble-shoot my power antenna. The motor and the cable ribbon appear to be fine, so I have turned to the relay. Is this the power antenna relay? It was connected to wires in the rear storage compartment that includes the wires coming from the antenna. It has a special place in the styrofoam below the tray. There is no part number on it and it does not look like the antenna relays in the parts catalogues - they only have 4 blades. If this is the power antenna relay does anyone know what the part number is? If it is not what is it for? Thanks much.
  • Jim P.
    • February 25, 2010
    • 58
    Re: 1994 Corvette Power Antenna Relay
    Well I found out that this is not the antenna relay. Also I was able to get one at the local auto parts store it is Standard Relay RY116. The radio would not work without it but the antenna works with or without it.
    Thanks for the views.
