When I turn my lights on I smell wire insulation (I think) burning after about 5 minutes. Turn the lights off no more smell. I had the instrument panel fuse blow a few times recently. I am curious if there is a ground somewhere I can check and clean to perhaps help this situation, or would one of the lights bulbs that illuminate the dash be causing this because it would not be grounded good in the cluster frame? I don't recall if the cluster frame grounds the bulb to make it illuminate or not? Any ideas?
Lawrence
Lawrence
