Did all 1966 Vettes with Base Engine receive the front steering stabililizer shock? - NCRS Discussion Boards
  • Larry E.
    • 1652
    Restoring a 66 Base Engine Coupe. Did all of them receive the above? Did it make a difference if the
    car had the N40 option or not? If they did was it received through all of the build? My car was built in the
    1st two weeks of the build.(Sept.) Thanks in advance-Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 15610
    Re: Did all 1966 Vettes with Base Engine receive the front steering stabililizer shoc
    The answer is yes except for models with power steering (N40) in which case the hydraulic boost cylinder replaced the steering damper.
