With the recent threads regarding vacuum advance cans and running temperatures and general engine performance I decided to finally check my car. I've had to read and re-read the information from Duke and Lars for it to hopefully sink in to my limited brain capacity.
This is my 67 L79 with as far as I know stock engine internals and distributor (1111196). The only things I've done to the ignition/engine electrics since I've owned the car is install a single wire points elimination kit, new spark plugs and new spark plug wires, all done within the last year.
Following is what I did and found on my L79:
Idle – 750rpm
Initial timing 10o BTC
Vacuum measured at idle – 14.5-15 in. hg (idle mixture set to max vacuum measurement)
Vacuum can on the car in the beginning was a B33, readings were Start @ 4 in. hg and full in at 10.5-11 in. hg
Vacuum can was replaced with a B26 can (per Duke's recommendation) which is rated as Start @ 5-7 in. hg and full in at 11-13 in. hg
Timing measurements were as follows:
Total advance at idle (with vacuum can connected) – 26.8o (this conforms to correct parameters 10o initial and 16o full in vacuum advance per service manual specification)
Total advance (with vacuum can disconnected and plugged) at various rpm levels:
I can't explain the 900 rpm extra 5os. I sort of suspect the 1500 rpm reading was a combination of holding the rpm steady and getting the dial back timing light dialed in.
Should I be satisfied with the tuning as set currently? Any reason to mess with changing the advance springs?
Also, per Duke's paper, he says WOT timing should be in the 34-40 degree range for small blocks. How do I measure the full advance? I don't particularly want to jam the accelerator to the floor and hold it there while trying to dial in timing light to get a reading for timing. Is there some lesser rpm where the centrifugal advance will be all in to measure at?
Don
Idle – 750rpm
- 900 rpm – 15.2o (this is a little high per specs of 10o initial plus 0o centrifugal at 900 rpm)
- 1200 rpm – 19.5o (this conforms to specs of 10o initial plus 9o centrifugal at 1200 rpm)
- 1500 rpm – 22.4o (this is a little low per specs of 10o initial plus 15o centrifugal at 1500 rpm)
- 3000 rpm – 30.2o (no service manual specs for 3000 rpm)
Don
