I'm getting ready to paint a '66 427 engine and was wondering who makes the correct shade of orange? I did a forum search and couldn't find the answer. Thanks
Engine Paint
Re: Engine Paint
The consensus I recall from TDB discussions is there isn't a "correct shade." There is noticible variation across batches, suppliers, years. And there was little factory concern about shade because it was cheap bulk engine paint.
Bowtie cars don't help much since the color fades and shifts considerably with time and heat cycles.
Because of the above, I was taught to not deduct for shade unless it's waaay off.
I would choose high quality rattle can engine paint from a local parts store then note the brand so you know what to use for touch ups. Just as durable and authentic but much less expensive than a boutique brand.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Re: Engine Paint
The Bill Hirsch Chevrolet Orange CAN be bought in rattle cans. Buy 3 or 4 cans so you have plenty for touch ups later on. I painted the engine the first time during the restoration in 2009 and had to re-paint the valve covers last spring after a brake fluid spill. This was done with paint bought just weeks after the accident, matched fine. Over time, the paint will darken and dull some due to repeated heat cycling. The paint formulas (color) from parts store paint will vary so that is not a deterrent from using the Bill Hirsch paint. The Chevrolet Orange paints from the parts stores is not the correct color. The only one close is the Martin Seynor brand Chevrolet Orange bought at NAPA.
James- Top
Re: Engine Paint
JamesMark Edmondson
Dallas, Texas
Texas Chapter
Re: Engine Paint
Cliff,
I would recommend buying Bill Hirsch Chevrolet Orange. I used it on a ‘65 396 restoration and it looks great. Went through all levels of flight judging with no deductions. Go to www.hirschauto.com.
James- Top
Re: Engine Paint
FWIW> I found that the Bill Hirsch Chevrolet Orange and the Quanta Chevrolet Orange are very very close. Of course I do not
know if either has changed their formula recently. LarryLarry
LT1 in a 1LE -- One of 134- Top
Re: Engine Paint
The issue I'm seeing with the engine paints available at parts stores recently, is they are calling it "ceramic" or high durability, nano technology or the buzzword of the month, and the gloss is way off the charts. Color is ok, but is way too shiny. If you ok with the wet look, then paint FLAPS would suffice.NCRS New England Chapter Chairman 2022, 2024
N E Regional Chairman 2024
1967 Corvette Convertible Under Restoration
1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0- Top
