70 Hole in fender rail - NCRS Discussion Boards
  • Dennis D.
    • March 1, 2000
    • 1071
    I've been noticing a hole in the driver side fender drip rail. I first assumed it was because of a replaced fender. I believed that hole is for additional a wire clip I thought began on 71's. The 70's wire and hoses appear to have a loop from the front of the fender up beyond the horn relay, past this hole area. Always looked messy to me.
    Just saw this 70 unrestored with the same hole. Is it an earl late 70 thing?
    • 15573
    Re: 70 Hole in fender rale
    Dennis
    I believe it is a later 1970 thing. To the best of my recollection my early 1970 does not have it.
    • Dennis D.
      • March 1, 2000
      • 1071
      Thanks Terry
      Found another well documented, unrestored, last week production, same hole.
      71 fender
      • Mark E.
        • April 1, 1993
        • 4498
        My '70, #12931, has a hole on the vertical part of the drip rail on the driver's side, and a hole on the horizontal lip of the drip rail on the passenger side.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Dennis D.
          • March 1, 2000
          • 1071
          interesting, have to look on my 12981 car. (June). Wasn't there a bracket over there for the long neck washer bottle tube? 71 also?
          like this...
          • Gary B.
            • July 31, 1979
            • 926
            1970 SN 14544 has the hole.
            Gb
            • Dennis D.
              • March 1, 2000
              • 1071
              And you harness has that "loop" to it ,seen so often on 70's.
              • Jerome P.
                • October 22, 2006
                • 607
                My '72 has the holes on both the left and right side of the drip rail's horizontal surface. It also has plugged holes on the vertical surfaces (both sides) What is the purpose of these?
                  • 11608
                  Those plugs are called rivets, and they hold brackets.
                  • Jerome P.
                    • October 22, 2006
                    • 607
                    My Bad. They are most certainly rivets and not plugs. I should have known that. Old age, I guess.
                    Help me out with the purpose of the holes.
                    • Bob B.
                      • January 31, 2007
                      • 524
                      Patrick I assume your engine suffix code stickers the correct ones how do I buy them 67 350hp 4sp
                      Thanks, Bob
                      #7,502 4/70 has the pass side hole open and driver side has under hood wiring loom holder riveted in to the hole
                      • Leonard M.
                        • September 7, 2009
                        • 236
                        Jan, 1970 #1889.
                        • Tom F.
                          Infrequent User
                          • June 30, 2003
                          • 13
                          2/19/70 #4103
                            • 15573
                            Re: 70 Hole in fender rail
                            It looks like we are on to something here.
                            • Mark E.
                              • April 1, 1993
                              • 4498
                              Originally posted by Tom Flanagan (40176)
                              2/19/70 #4103
                              Tom,
                              Your photo shows the two holes also in #12931 described in my prior post.
                              As Dennis mentions in his post, the passenger side hole is used to mount the plastic w/s washer reservoir used in some vehicles. Big blocks used a bag mounted on the firewall instead of this reservoir. Hence the unused hole in these cars?
                              Mark Edmondson
                              Dallas, Texas
                              Texas Chapter
