Ready to paint the old car white and can't get good match here. Can anyone recommend a supplier for white? Also best way to get hood stripes installed?? thanks Ronnie
1970 ZR1 paint
Re: 1970 ZR1 paint
Ronnie,
Suggest you contact Tom Ames. Tom can be found in the Member's list.
Gary
....NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
Re: 1970 ZR1 paint
This may be worth an inquiry.
- Top
Re: 1970 ZR1 paint
No doubt. Code 10 white a gallon for $50... CHEAP.
That ASIDE I will attest to the Help provided by John Ballard, I recently repaired the front wheel lips, corrected some gaps, and fixed a few stress cracks a 71 Warbonnet Roadster and his help with the color match was invaluable. (I provided him with the mix formula in chroma)James A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
Re: 1970 ZR1 paint
You can tint the paint to match your original. Years ago, when I was still painting, most paints, unless you got a factory pack, would have to be tinted to match. Some of the factory packs were not a perfect matchDick Whittington- Top
Re: 1970 ZR1 paint
Hood stripes... if the car has the variable stripe in NEEDS TO BE DONE CORRECTLY for the car to have the right appearance., WRONG LT1 stripes are a pet peeve of mine... IMHO any wrong stripe just kills the look of a factory original restoration.
The thick thin stripe is unique and you should question whomever is going to apply it and make sure they understand the difference.
James A Groome
