1973 L82 - pump to carb fuel line - NCRS Discussion Boards
  • James G.
    • August 22, 2018
    • 783
    I am working on a 1973 L82 and the pump to carb fuel line was cut years ago, I have all of the pieces and compared to the reproduction I received from the customer the reproduction will not fit and is not the same as the original.
    I have nice Ridgid Tubing benders in differing tubing sizes, so I also tried to bend my own, however you need at least 2 different radius 3/8" tubing benders, I do not have one tight enough for 2 of the bends required.
    Does any one know of a good source for the 3/8 hardline?
    James A Groome
    1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
    1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
    My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
    Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
    • 11608
    Re: 1973 L82 - pump to carb fuel line
    I doubt that the 73 L-82 line is vastly different than the ones used on 72 350s with Quadrajets, and I've never had any problem with replacement lines. Where did you get yours?
    • Jimmy P.
      • June 24, 2014
      • 1695
      I bought my Replacement line from Paragon a few years ago and it was a perfect fit. Even though I have an L48. You could try them.
      Jimmy
      1973 Convertible
      L48,M20,N40
      Mille Miglia Red/Oxblood
      • James G.
        • August 22, 2018
        • 783
        Turns out it came from Ecklers.
        James A Groome
          • 11608
          Who bought it from someone else.
          I have likely purchased mine from both Paragon and Corvette Central with no issues.
