I'm looking for response from those who have actually accomplished drilling the kick-up frame section for acceptance of shim-retaining cotter key ('69-'70 & on style) with body-on-frame, completed car configuration. I know how to locate the hole's position & yes, how shims "... cannot come out ..." if tapped down into the frame pocket, etc, etc.
If you have photos, illustrations, narrative of how to accomplish while protecting the body/wheel well opening fiberglass, that would be helpful. Would a 3/16" dia, 12" length, aircraft extension drill bit be appropriate? Does the body-on geometry allow drilling the hole 'straight thru' the outboard and inboard frame rail metal, while remaining perpendicular to vehicle axis?
Shims are the typical aftermarket slotted, stainless, 4-1/2" o/length. Thanks in advance.
Jeff
Jeff
