This pix is the headlight header to corner seam split below the waist line. Pix taken up from the bumper. It is not a glaring problem unless you look over every inch of the car. To halt split progression I plan use Loctite epoxy from the inside, their mixing syringe stuff, and work it into the bonding strip from the inside. I hope to work in enough but to not push it out the crack.
Any recommendations on a filler to work in from the outside? Would be great if one existed that would not.damage the BCCC paint and could be wiped off the paint before setting up. Split at the widest is no more than 1.5 mm. A fine jewelers file to smooth it out, touch up paint and seam should be inconspicuous.
Gerry
Gerry
