Spin-on Oil Filter adapter questions - NCRS Discussion Boards
  • Daniel D.
    • December 9, 2009
    • 105
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Spin-on Oil Filter adapter questions
    I used the Mr. Gasket adapter - so I'm not familiar with your adapter.
    The NAPA 1060 Gold filter (which is actually black) is a nice choice (I think they are rebranded WIX filters)...you can peel the NAPA label off and its at least the same color as the original canister...
    • Daniel D.
      • December 9, 2009
      • 105
      Thanks Frank.
      • Dick W.
        • 10483
        Believe the only difference in the filters is the PH 5 is conventional filter media and the PH 13 is synthetic filter media
        Dick Whittington
        • Daniel D.
          • December 9, 2009
          • 105
          Thanks Dick. I did a little more searching, and learned that the filters are the same basic size but the PH5 has an antidrainback valve and the PH13 does not. But it sounds like they are interchangable.
          Can anyone provide an answer to my question about whether the
          the orientation (clocking) of the bypass valve matters? It can be mounted in two different 180 degree opposed positions? Thanks.
          • Ken A.
            • July 31, 1986
            • 929
            It goes next to the block & does not use a gasket.
