Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 Fed up with tri power - NCRS Discussion Boards
  • Rich G.
    • August 31, 2002
    • 1396
  • Dick W.
    • 10483
    Re: Fed up with tri power
    Have you looked at the FiTech 3X2 electronic FI. Would be great setup and with the air cleaner on it would look stock. I have a 496" with a ProCharger on it in the shop. We tried three different EFI setups before we found one that would produce an acceptable a/f ratio from idle to 6,500 rpms.
    Dick Whittington
    • Rich G.
      • August 31, 2002
      • 1396
      Dick
      I have not, but I will. I assume a new fuel pump and sensor(s) would need to be added. Thanks for the info
      Rich.
      • Patrick B.
        • August 31, 1985
        • 1986
        If you want to use a factory aluminum manifold and a Holley 4 barrel, the 71 LS-6 manifold is the only one that will fit under your hood. If you would rather use a Quadrajet which is much more reliable than a Holley, I think the 69 390hp used an aluminum Quadrajet manifold. I think 68 and 70 390 hp used an iron Quadrajet manifold that would also work and are more plentiful.
        • Edward D.
          • October 25, 2014
          • 206
          The GM Q-jet manifolds are all oval port. The 68 L71 has rectangular port heads. There are several GM aluminum rectangular port manifolds for Holleys that will work. You can also go aftermarket with an Edelbrock manifold, just remember to match the port configuration.
          • Rich G.
            • August 31, 2002
            • 1396
              • 43193
              Edward------
              The only GM manifold with rectangular ports and which will fit under a 1968-72 standard big block hood is the LS-6 manifold. No others will work.
              As far as aftermarket manifolds, the only one I know of that will work is an Edelbrock single plane manifold. I do not recommend single plane manifolds for street use.
              • Chris H.
                • April 1, 2000
                • 837
                  • 43193
                  Originally posted by Rich Giannotti (38594)
                  I have a 68 L71. I’d really like to drive it more than 150 miles a year but too many times there is a problem with the Tri Power setup. If it’s not fuel lines leaking, it’s carbs leaking or floats sticking or fuel leaking down the throat of a secondary flooding out the engine. I’ve had this car for 16 years and tolerated it because I had a shop who could fix things quickly but now I don’t and I’m just to old to screw with it every time I take the cover off.
                  So, I’m considering taking the whole set up off, storing it away in a safe way and replacing it with a manifold/ 4 barrel combination that works. The heck with date codes. A new carb out of the box would be lovely. I’m looking for suggestions that don’t include trying to fix these carbs again. The next owner can enjoy the tri power carbs. I’m done.
                  Any suggestions?
                  Rich------
                  If I had a Corvette with 3X2 set-up, the first thing I would do is to remove it and replace it with a single 4 barrel. The 3X2 set-up was all about "glitz" and "cachet" and never interested or impressed me. Never.
                  • Danny P.
                    • Today
                    Tri- power set up run a simple center 2 barrel Holley remove the both linkage from the both end carburetors and just set up the center Carburetor and see what happens, sound like you got float level adjustments which are very easy to adjust and leaky fitting to deal with.
                      • 15573
                      This is the: "the only thing worse than one Holley is three Holeys" thread
                      • Patrick B.
                        • August 31, 1985
                        • 1986
                        • Patrick C.
                          • January 16, 2013
                          • 327
                          FWIW I would not run fuel with ethanol in it.
                          • Rich G.
                            • August 31, 2002
                            • 1396
                            • Robert W.
                              • June 28, 2018
                              • 134
                              It sounds like you need a good mechanic who really, really knows Holley carbs and how to set them up. I know somebody up here in MA (PK Machine, Fitchburg) but its probably too far away. You could give the shop a call and he may know somebody in your area... Finding anyone who really understands carburetion is getting very difficult these days.
