Hi Guys,
I'm looking to buy a replacement new Holley 3810 for my '67 small block 300 hp coupe.
My car has a generic Holley 1850 carb on it. Athough I've had it rebuilt, I continue to have problems with gas smell, hard starting, and occasional backfiring through the carb. Enough I say. While on a 700 mile road trip this past weekend the car backfired through the carb hard enough to scare my wife into agreeing on the merits of replacing the existing carb. Although pricey, I'm seriously considering biting the bullet (and buying my dear wife a trailer load of shoes!) to get a NEW replacement, and correct, Holley carb for my car.
I see two vendors on eBay that are selling (presumably) brand new Holley 3810 carbs:
SPECIALTY PARTS DIRECT
CRANE'S CORVETTE SUPPLY
Crane's price is $84 cheaper than SPD. I've read mixed reviews about Crane here, but nothing that would prevent me from buying a new part from him.
My questions are:
Thanks for sharing your advice with me!
My questions are:
- Any concerns with buying the new carb from Crane or SPD ?
- Anyone here buy a new Holley 3810 for their '67? Did you buy it from one of the above sources? Did your car run better after replacing the carb?
- My current carb uses an electric choke. Should I retain that or go back to the stock choke stove setup? My car has the cast iron OEM manifold. From what I can tell, to go back to the stock setup I'll need to buy a "Choke Intake to Holley" kit, also sold on eBay for about $32. Does this kit have everything I'd need to take the choke back to stock configuration?
- Should I buy a new carb to intake gasket? These are cheap. Or, should I just re-use my old one?
- Will the new carb work fine "out of the box"? Or will I need to make a bunch of adjustments to get it running right?
- Anything else I should consider when installing a new Holley 3810 on my car?
