Today I ordered a brand new Holley 3810 carb from Crane's Corvette for my '67 Coupe with 300hp engine w/ OEM cast iron manifold. I'm told the new carb comes with a gasket in the box.
I read here that I should also install a "heat shield" between the manifold and the carb gasket to reduce the chances of percolation on hot days. However, I'm having trouble determining what this "heat shield" is looks like so I can order the correct part.
I found an eBay listing for a "1964-67 HOLLEY CARB TO INTAKE GASKET CORVETTE 3124 2818 3247 3367 3810 ALUMINUM"
This is not expensive at $6.95. This single piece has two round holes and one larger slotted hole. However, in the listing photo it is grayish-black, not reflective metal. I'm suspecting this is merely the gasket that's included with the new carb, so isn't what I need.
I searched the Holley website for "heat shield"and got this:
https://www.holley.com/products/fuel...s/parts/108-70
This is a 3-piece "kit" ($34.30) including two gasket-sized pieces with a single large square hole in the middle (i.e. no slot or holes), and one large aluminum plate that would cover a fair bit of the intake manifold. Although I imagine this would be quite effective at shielding the carb from manifold/engine heat, it sure wouldn't look stock, and might interfere with linkages, etc.
So, what is the proper "heat shield" I should get for my new Holley 3810?
