What really should be done to affect change-over (1965 Corvette example):
And if you already have all your Flight Awards and no longer care about NCRS Judging deductions, then the icing on the cake would have been to change out the old GM A6 compressor for a new Sanden-style compressor (with mounting kit), and a puller electric cooling fan for those HOT August Nights parades, and maybe add a newer multipath condenser to maximize cooling.
Forsooth, there be some good news here for those caught yet in the midst of a restoration. The Santech HNBR green O-rings are compatible with both R12 and R134a, and are compatible with the different lubes used with these two refrigerants. So you may start with the Santech HNBR and be in the green when you decide to change over later. Alas, Green is not always green. Since there are no official standards for these material colors, and may vary from one manufacturer to another, make sure that you are getting Santech HNBR, which they color green.
Critique and knowledgeable comments will be appreciated, since I have strived to make this as complete and as correct as possible.
- Find any gas leaks in the A/C system and repair
- Replace dryer recommended (difficult to properly flush)
- Replace expansion valve with new replacement GM unit that is balanced with R134a
- Replace all
