Diagnosing what seems to be a percolating/heat soak issue. Want to get back to stock configuration before I start. Previous owner seemed to combat with carb shield/insulators and fuel line/ heater hose wrapping.
I'm thinking this vacuum hose routing isn't optimal for direct advance. Also, Appears to be 2 manifold vacuum sources. Haven't noticed that port below choke diaphram on 70 LT1's. Is this normal?
Here's a diagram I borrowed from an old Dr. catalog I had.
