63 Corvette Sebring silver
Re: 63 Corvette Sebring silver
Donald,
Tom Ames, NCRS' Body & Paint expert, at "automospe@aol.com" would be your best contact point.
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
How do you judge a color for correctness? It would of course have to be lacquer to be 100% correct.
It is well established the lacquer formula used in the 60's is no longer available.
Wouldn't the judges give 100% if it's close in tint?
Other deductions for application and condition of course, I am considering the tint only.
Such a subjective thing as color would be very difficult when one is attempting to match the original exactly.
Even the originals would have likely changed slightly in hue over the years depending on exposure and storage.
If the color is missed by a mile full deduction just like a color change.
However, the standards shouldn't be impossible to obtain.
How is this handled in judging?- Top
Just went through it at back to back regionals. The color was matched to original paint on the car and the 63 Color book. Here is the car at 2 different events. There were no issues with the metallic content or the application. You can see how lighting changes the tint of a color. Good luck!- Top
I know you cannot get the original 63 lacquer formula. We mixed up the formula that they call for and painted it on to a test piece of fiberglass and put the correct clearcoat that they called for and it did not match a piece of the original 63 Corvette Sebring silver that I have. So I am sure there is a modern car that has the correct shade of silver without going through making a one off color. Does anybody know what car would have this correct shade?- Top
Donald,I know you cannot get the original 63 lacquer formula. We mixed up the formula that they call for and painted it on to a test piece of fiberglass and put the correct clearcoat that they called for and it did not match a piece of the original 63 Corvette Sebring silver that I have. So I am sure there is a modern car that has the correct shade of silver without going through making a one off color. Does anybody know what car would have this correct shade?
Again, contact Tom Ames.
I have recently matched some Corvette Metallics and the closest I have gotten is to scan an actual car then reduce the metallic by 25% then try your spray outs and adjust from there. --- going from the converted formula you end up with a color NO WHERE CLOSE.
I saw the The Jay Cline original paint Z06 at the regionals and took photos... it has VERY NICE COLOR and Metallic and should be easy to compare with a spray out.James A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
I should have mentioned that I sent samples to John Ballard and appreciate his help in getting the color correct for another member's Warbonnet Yellow LT1 roadster...
I implore everyone to take advantage of the resources provided by the NCRS - helping get colors correct is one of the greatest services offered.James A Groome
