C2 Tack Drive Cable - NCRS Discussion Boards
C2 Tack Drive Cable
  • John A.
    • July 30, 2008
    • 41
    C2 Tack Drive Cable
    • 15610
    Re: C2 Tack Drive Cable
    The first thing that comes to mind is that the distributor installation is wrong creating an excessive bend in the cable. Proper indexing of the wires on the cap (shown in your '63 shop manual) and distributor installation should have the cap window approximately normal to engine centerline. How is yours oriented?
    Remove the shield, snap a photo and post.
    Improper wire indexing/distributor installation is a common problem.
    • Bob R.
      • June 30, 2002
      • 1595
      Another possible problem with you cable, if you had your transmission removed at some point and they did not brace the engine from below to keep it in proper position the engine will tilt back. It can tilt back enough to put a bend in the cable near the distributor. If this is the case you should either straighten the old cable casing.
      • John A.
        • July 30, 2008
        • 41
        Thanks Duke. I will take a picture and post.
        • John A.
          • July 30, 2008
          • 41
          • John A.
            • July 30, 2008
            • 41
            • John A.
              • July 30, 2008
              • 41
              • Timothy B.
                • April 30, 1983
                • 5177
                John,
                Remove the top shield that's over the distributrcap and snap a picture or two of the cap and wires as they are now. I'm sure someone will post as to the installed position of the distributor.
                • John A.
                  • July 30, 2008
                  • 41
                  I will try to snap a picture or two.
                    • 15610
                    Originally posted by John Abbott (49249)
                    Hi Duke,
                    i looked at the section in my shop manual on ignition
                    circuit (6Y-26 thru 6Y-29) but couldn’t find any reference to indexing of the wires on the cap. Also, I don’t understand what you mean by having the cap window approximately normal to the engine enter line. So I can’t tell how mine is oriented. What is the shield that I should remove and snap a picture of?9
                    See Fig. 52, page 6Y-28, bottom right hand corner of the page. "Normal" means the plane of the window should be approximately perpendicular to engine centerline.
