My 1963 parking brake gives all indicationsof working on level ground however it will not hold the car on a steep incline.
Allbrake components are completely restored or new reproductions and the drumshave been turned
The servicebrakes work fine
Troubleshooting with the rear off theground and the rear drums on or off;
Onlythe right rear brake shoe is engaging when the parking brake is pulled
Theleft side parking brake shoe lever and spreader bar move when the parking brakeis pulled (or the equalizer nut is tightened) but not enough to engage the leftrear brake shoe
Thetwo connected parking brake cables move freely around the equalizer
Potential next steps;
Measurethe force required to move each cable individually a set distance. Then trimthe spring at the end of the cable to equalize the force (really don't want to try this)
Any suggestions / help would be appreciated
