1963 glove box light and fuse - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1715
    I just replaced my 1963 glove box and straightened out the non-factory light in the box.
    The new harness came with the correct end but I figured there was no way to remove the old clip from the original light without making a mess of a difficult to find light.
    So I decided there was going to be a splice somewhere.
    When you pull out the glove box it is difficult as you can't disconnect the light (it will not fit though the stock hole in the glove box liner without disconnecting the light from the wire and the light assembly will not fit through. Pictured is my solution with the splice. (Note; I bought an in-line fuse but did not use it, picture below).
    Now the glove box light is fused and the assembly hidden above the box where it is out of sight.
    Rick
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 1963 glove box light and fuse
    That wire is always hot so that's not a bad idea - I just put a bullet connect on it with the female end on the power side for safety...
    I hope you got an NOS or good used light switch - the repros are defective crap...
    The crimped part around the plastic plunger fails after a while and that piece lifts out of the switch face and you no longer get the ground to make the light operate - pizz poor part.
