Correct dipstick 1968 427/390 - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 543
    Re: Correct dipstick 1968 427/390
    Originally posted by George Wright (34257)
    Changed oil and filter -specs called for 6 quarts— is this correct?
    Dipstick reading is 1 quart over filled.
    Attempting to add photos of dipstick, do not see option for this—working from iphone
    George------
    6 quarts is correct for all 1965-74 Corvette big blocks assuming the car has the correct oil pan. The correct oil pan has a REAR drain plug. Most other Chevrolet big blocks used a SIDE drain plug. These sometimes end up on Corvettes. It's easy to check.
    Correct dipstick should have a white plug on the end of the handle. Otherwise, does the dipstick have a part number embossed on it (on the lower part of the blade)?
    • George W.
      • May 31, 2000
      • 543
      • Blair K.
        • September 27, 2012
        • 170
        https://www.forums.ncrs.org/showthre...ion-needed-***
        • George W.
          • May 31, 2000
          • 543
          Okay,
          It seems that I have the correct dipstick ( the ADD mark is apx. 1 1/2" from the bottom tip of the dipstick)
          Reads a full quart over full.
          Could the tube be too short?
          Does anyone have a measurement for the tube?
          G
          • Ray K.
            • July 31, 1985
            • 369
            George,
            Without pulling the tube from the pan, I have right at 12 & 3/4" from the pan tube lip to the top of the tube . Probably another 1" or a bit more inserted into the pan tube for a total length of approx 14".
            Ray
              Originally posted by Ray Kimminau (8917)
              George,
              Ray
              Ray and George------
              As you know, the important dimension is that from the upper end to the collar which seats on the oil pan's extension tube. The 1965-E67 GM #3862732 and L1967-E1970 GM #3870324 were as mentioned 12-3/4". The late 1970-74 tube, GM #3981089, was 19-17/32" developed length from upper end to collar. These are the only tubes ever used for any 1965-74 Corvette. Any other length tube is incorrect. In addition, the correct dipsticks have to be used with correct tubes in order for the dipstick reading to be accurate.
              The GM #3862732 or 3870324 tubes must be used with dipsticks GM #3860316, 3925520, or 3959158
              The GM #3981089 tube must be used with dipstick GM #3981088.
              George: if you have the correct dipstick and correct tube and you are still getting an inaccurate dipstick reading, then I would say one of three problems are involved:
              1) you do not have the dipstick tube fully seated in the oil pan's extension tube, or;
              2) you do not have the dipstick fully seated on the tube, or;
              3) you have an incorrect oil pan.
