Brake wheel cylinders-1964 - NCRS Discussion Boards
  • Jack J.
    • July 31, 2000
    • 640
    Disregarding configuration, does ANYONE, make a USA made quality wheel cylinder? Jack J.
  • Larry M.
    • January 1, 1992
    • 2688
    Re: Brake wheel cylinders-1964
    If you have old ones, have then sleeved............or buy used ones and sleeve them.
    Also get the GM part Number and search Ebay and the internet. Also "1963-64 brake cylinders" may also work in a search function vs the part number.
    Larry
    • Ed S.
      • August 6, 2014
      • 1377
      I purchased a set, front & back, at NAPA 2 years ago - no problem, they work just fine. One thing though, the bleed valve that comes with the cylinder has a metric hex head - I purchased a set of bleeding valves from LIC, 3/8 inch hex and the treads were a perfect match to the threads in the cylinder. They fit perfectly too.
      Ed
      • Jack J.
        • July 31, 2000
        • 640
        Just wanted to know if there is any company currently making American Made wheel cylinders? Thanks, Jack J.
        • Ed S.
          • August 6, 2014
          • 1377
          Not sure about that - I think the companies are still US but the parts are actually made elsewhere. I think the brake cylinders were made in Mexico - Mexico stuff is not too bad, Federal Mogul, AC Delco, Raybestos, and others are down there - most stuff in parts stores are made in Mexico.
          Ed
          • Jack J.
            • July 31, 2000
            • 640
            Took a "VERY" remote chance on Rock Auto. Parts (front cylinders) arrived via Fed-Ex yesterday. One cylinder in a ACDelco Durastop box, the other cylinder in a ACDELCO "Professional" box. BOTH boxes labels say "Made in China". Again, I don't care about configuration, just would prefer real Made in USA parts. I know, that seems to be our problem these days. Rear cylinders will arrive today via USPS. Should be interesting. Jack J.
            • Jack J.
              • July 31, 2000
              • 640
              Rear wheel cylinders follow-up. Both from Rock Auto in ACDelco "Professional" boxes, Made in China. Interestingly, picture of left cylinder on Rock Auto's website shows left cylinder ONLY, embossed with #7565 - MADE IN USA. Obviously, either OLD picture or false advertising! Time to move on. Jack J.
              • Richard G.
                • July 31, 1984
                • 1715
                Rock Auto only sells one thing, a low price.
                My friend purchased a power window motor for his Silverado from Rock Auto.
                Didn't work, even once, before it broke.
                Although he purchased another one elsewhere it was also Chinese.
                At least it worked and kept working.
                I needed the same motor for my Silverado.
                Paid twice what the aftermarket part cost for one from from GM.
                It was also made in China. The original had made in USA all over it.
                Even if companies can make it here they will switch to Chinese and pocket the extra profit.
                The way it is in a global economy.
                Rick
                • Alan D.
                  • January 1, 2005
                  • 2027
                  Try some auto shows that have parts for sale, may find some still in the box. Then there's the junk yards and have them rebuilt.
                  • James W.
                    • December 1, 1990
                    • 2640
                    Anyone recommend a vendor that will re-sleeve my original '64 brake wheel cylinders at a reasonable price? Lone Star was way high per wheel cylinder when I got a quote from them.
                    James
                    • Ed S.
                      • August 6, 2014
                      • 1377
                      James
                      James - Try White Post Restorations in Virginia. Not a Corvette only restoration shop and I haven't had any work done by them but I know a few guys that have had brakes and other items for their classics (Packard, etc) done there and the guys said the quality of the work was excellent. Good luck. https://whitepost.com/
                      Ed
                      • Scott P.
                        • April 30, 1992
                        • 178
                        Jack, I have sent 8-10 Corvette master cylinders and lots of wheel cylinders to this man. Does nice work but only sleeves, you have to kit them yourself. The last set of wheel cylinders Mark sleeved I bought some of those foreign wheel cylinders from Rock Auto, gutted them and used the parts to sleeve the original cylinders on a 57. Everything fit and is working fine. Scott
                        • Dan D.
                          • November 5, 2008
                          • 1323
                          FYI. White Post rebuilt my 57 wheel cylinders. Did an excellent job and fast turn-around. I had them back in 1 week.
                          They sleeve with brass, which I prefer over CRES (stainless). The aftermarket ones I bought previously were junk, so I 'junked' them and had the originals rebuilt.
                          -Dan-
                          • Frank D.
                            • December 27, 2007
                            • 2703
                            I run the NAPA wheel cylinders on all 4 corners of my 63 (I suspect they are Dorman parts), they work fine and have for 4 years.
                            I have the original wheel cylinders boxed up and maybe I'll have 'em overhauled at some point...
