'67 half shaft u-bolt - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3607
    Can someone please give me the size of this bolt. GM #3843384. Someone in the past failed to peen over the French lock. Something else to check while under the car.
    Leif
  • Gene M.
    • April 1, 1985
    • 4232
    Re: '67 half shaft u-bolt
    7/16” fine thread
    • Larry M.
      • January 1, 1992
      • 2688
      Agree.........but specifically 7/16 x 20-1-1/8 Grade 8. Paragon and others have them. You hardware store may have something as well, but the 1-1/8 length may be an issue unless you cut it........and Grade 8 is tough to cut.
      Larry
      • Leif A.
        • August 31, 1997
        • 3607
        Thank you gentlemen. They're all loose back there. 60-90 lb ft sound right?
        Leif
        • Gary J.
          • April 1, 1980
          • 1229
          Check the assembly manual it should have the torque values. I am not at home to check my chart.
          • Larry M.
            • January 1, 1992
            • 2688
            Chevrolet Service Manual says 75 ft-lbs. Lightly oiled. A regular steel French Lock will begin to deform at torque below the spec. Use stainless steel French Locks ( a bit hard to find, but available) and/or a bit of never-seize just under the bolt head.
            French Locks only go on one way/orientation to allow you to get a solid socket on the bolt head. Otherwise you will have difficulty. Check the others on your car for correct orientation, or correct orientation is is shown n Chevrolet Service Manual pictures.
            Larry
            • Richard G.
              • July 31, 1984
              • 1715
              Since they were all loose all the bolts are now suspect.
              To be on the save side I would replace all of the them.
              BTW; you can see the French Lock deformation in the direction of tightening the bolts. Just like Larry predicted.
              This may not be a lock tab failure but an under torque situation.
              After a Corvette is put back on the road, after servicing the axles, I recommend they be checked for torque after 50 miles.
              Then bend the tabs over. SS tabs sound like a great idea.
              Rick
              • Leif A.
                • August 31, 1997
                • 3607
                Thank you everyone. Last evening I ordered 8 new bolts and 4 SS french locks from Paragon. I was going to ask about a touch of Loctite blue...thanks Larry.
                Leif
                • Richard G.
                  • July 31, 1984
                  • 1715
                  For those that don't know, Loctite blue is the stuff for "service removable" items.
                  I think it's a great idea. Works better than the french locks.
                  Only down side it you will not be able to re-torque them.
                  But not much because they will not come loose.
                  Rick
