71 LS5 Rad Shroud Replacement and Rad support - NCRS Discussion Boards
  • Kenneth T.
    • March 23, 2008
    • 631
    I had a wheel alignment several months ago. I went for a drive recently and the left front wheel collapsed. The upper control arm bushing came out. I (assume) bolts were not tightened. Very lucky, only a block from home, driving slow, no body damage.
    Now, the upper control arm bushings needed replacing and a piece of the fan shroud was broken. I ordered a "correct" fan shroud from Corvette Central. Their replacement shroud was $186 and the correct shroud $350. After struggling with the correct shroud for a long time I removed it, measured it and all the dims in several places were off from my original. The visual look was perfect.
    I have checked the Assembly manual for dims, no joy. I would like to find out what the distance is between the two studs on the lower rad support brackets. The "correct" replacement is 25 1/2" and my shroud is 26". Is there any way I can find the original dims for the shroud and support. CC is telling me I got what I ordered, so return shipping/boxing is all on me.
    Tks Ken
  • Tom L.
    • October 17, 2006
    • 1439
    Re: 71 LS5 Rad Shroud Replacement and Rad support
    Hi Ken, sorry you had this issue. Call me if you need to, we have similar cars and I have my shroud and a piece of a shroud that you may be able to use to patch things up. Hope all is well, say Hi to Nina.
    Tom
