1960 Differential identify - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
  • Carl R.
    • October 31, 2018
    • 63
    Re: 1960 Differential identify
    The Corvette by the Numbers book is showing that the stamped ID number should be on the flat area between the two nuts on the right hand side of the carrier at the same level as the #2 shelf as per your picture. The book is showing that the stamping are not a heavy stamp, so they might be hard to see. I would suggest some paint remover and a small wire brush to clean the area.
    • David H.
      • November 11, 2009
      • 777
      A quick shot with the sand blaster did the trick and there it is. AN 114. 3.70 posi with a 4 speed.
      Dated Jan. 14. Numbers matching.
      Thanks for the help Carl.
