1966 C60 main harness routing to right of cluster - NCRS Discussion Boards
  • Robert W.
    • June 28, 2018
    • 134
    Hi, I'm having difficulty figuring out the main harness routing to the right of the cluster. The AIM seems to just show it on top of the cross brace, but that area is blocked on AC cars by the AC ducting (no clearance between cross brace and speaker. Does the harness route in front of the cross brace and under the AC ducting? I can't find any good pictures online and my original dash harness was a complete disaster...
  • Mel S.
    • August 31, 1992
    • 263
    Re: 1966 C60 main harness routing to right of cluster
    My 66 has the original wire harness. I will look and get back to you in a day or two
    Mel
    • Robert W.
      • June 28, 2018
      • 134
      Thanks Mel, I appreciate the help! -Bob
      • Peter M.
        • May 30, 2013
        • 358
        Robert,
        I have some pictures of my 67 if that helps.
        • Robert W.
          • June 28, 2018
          • 134
          I'm guessing all C2's with AC used similar routing so, yes, it would help! I've found a couple pictures on-line that suggest the harness goes behind and then over the LH center duct hose, but it's they're not very clear.
          • Peter M.
            • May 30, 2013
            • 358
            Robert,
            I thought I had better pictures, but most are from the passenger side.
            • Peter M.
              • May 30, 2013
              • 358
              Robert,
              A few more.
              • Mike B.
                • July 31, 1994
                • 838
                Excellent shots Peter. Any more? Valuable shots here.
                Mike
                • Robert W.
                  • June 28, 2018
                  • 134
                  Thanks Peter, Looks to me like it must wrap up and over the AC center duct (LH) based on the harness deformation. I'm dropping my body onto my new VPM frame on Friday (MaxJax two post lift), so I'll reroute the harness after that. Looks like I'll need to remove the speaker and grill so I can at least see what's going on in that area! -Bob
                  • Peter M.
                    • May 30, 2013
                    • 358
                    Mike,
                    I took a lot of pictures but they are never enough and there is never the one you really want.
                    • Peter M.
                      • May 30, 2013
                      • 358
                      Robert.
                      If I find more that I think could be helpful I will post them.
                      A word of caution, at some time in the cars past Bubba the Butcher removed the heater core so some of the wiring may not have been routed properly, I spent some time trying to clean things up when I put it back together. There isn't much room up in there.
                      • Greg H.
                        • 105
