Clutch fan leak - NCRS Discussion Boards
Clutch fan leak
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Clutch fan leak
    Here's one with the "this side up" repeated in ink stamp on the bi-metallic strip. I have another but the ink stamp is long gone and there's a "B1" stamp in place.
    • Ken A.
      • July 31, 1986
      • 929
      Re: Clutch fan leak
      This side up refers to the bi metallic strip & has nothing to do with the fan clutch.
        #18
        Re: Clutch fan leak
        Once I had a Delco coil spring type stored face down and it leaked a small amount of the fluid out of the pin valve under the coil spring.
        I have seen NOS unit boxes clearly marked...."STORE THIS SIDE UP". But which way were they stored in the box, face up or face down?
        This Delco/Eaton part shows it is stamped..."Store This Face Down" stamped on both ears of the face. Further research tells me that the hub shaft seal was the problem on this type and the clutch would leak the silicone fluid if stored "face-up/hub down".
        However, other manufacturers(Sachs) stated to store their fan clutches face up, as the fluid could leak out the pin valve under the coil spring. That's what happened to the older Delco unit I had.
        Here on a different part, the box is marked "THIS SIDE UP" but I wonder which way was the part placed in the box. Hard to see if anything is stamped on the face of this one.
        I suppose the safest way to store any fan clutch is in the "as installed" position.... i.e vertical.
        Rich
        Rich-------
        I doubt that the shaft seal was the source of in-storage leakage. If the shaft seal leaked in a static situation, I would think there would be a really big problem in an in-service, dynamic situation.
        I think the main leakage source for these clutches is the thermostat activated piston. There is no positive seal I know of for this piston.
        • Daniel D.
          • December 9, 2009
          • 105
          #19
          • Keith R.
            • August 31, 2001
            • 660
            #20
            Re: Clutch fan leak
            Its my understanding that the aftermarket clutches may initiate at a higher temperature than the originals. Is this correct?
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
            2013 427 Convertible
            Shade tree mechanic and
            B-52 pilot extraordinaire
              #21
              Re: Clutch fan leak
              Keith------
              Yes, with the aftermarket clutches it's more-or-less a "one size fits all". They are not calibrated for a specific application.
