I have a '67 coupe. Recently, when I start my 327-300hp stock original motor (rebuilt in the late 90's but only 20k miles on it since then), I sometimes see blue smoke. Once it warms up there is no blue smoke, as far as I can tell. The engine runs strong and doesn't seem to burn much oil. I drive the car maybe 1,500 miles a year.
I understand the smoking at startup can be caused by valve guide seals. Could it be anything else? Is this something that should be fixed right away?
Is there some type of oil additive that might help restore the seals to reduce the smoking on startup?
If I want to replace the valve seals, what are the recommended type to use?
I would likely hire a mechanic to do this job. How much time, roughly, would it take to do (hours) and more or less what should I expect to pay for a job like this? I realize labor rates vary across the country, but a ballpark idea of time and parts cost would help.
For your info, my car has factory A/C, and does not have K-19 (A.I.R.).
