Half Shaft Interference - NCRS Discussion Boards
  • Mark H.
    • July 31, 1998
    • 384
  • David H.
    • June 30, 2001
    • 1485
    Re: Half Shaft Interference
    Mark
    New shocks? If so, how long?
    Dave
    • Mark H.
      • July 31, 1998
      • 384
      Shocks not installed
      • Patrick B.
        • August 31, 1985
        • 1986
        Can't tell from the pictures whether shocks are installed. If they are not installed or if they are too long, the interference you describe happens.
        • David H.
          • June 30, 2001
          • 1485
          Mark
          Maximum extended rear shock length, I believe, is 14.25 inches. Longer than that and you get interference with half shafts (wear).
          Dave
          • David H.
            • June 30, 2001
            • 1485
            Mark
            Lift (both) trailing arms to ride height. A 9/16" socket (1/2" drive) placed (width-wise) between trailing arm and frame will approximate normal ride height. With both trailing arms in ride height position you can check for potential interference.
            (My guess, without shocks trailing arms can hang too low. )
            Dave
              • 15610
              Full shock extension is what limits rebound travel. That's the design. If the shocks are functionally correct there should be no U-joint grounding.
              This is more of a problem on '63s that have cast half shaft drive flanges. Later forged drive flanges have a different design that allows more clearance, so it should not occur once the shocks are installed.
