Good Morning,
I am a recent buyer of a nice driver level C1 Corvette. 1962.
I have been driving and enjoying this great car since I bought it in late April of this year. I have
When I bought it, the 327/300 hp engine had been replaced with a 350/300 hp from 1970. I believe that it was rebuilt at some point, because it feels very strong for an engine of that age, and that drives out well, with no issues.
I say no issues... The engine had a Carter WCFB carburetor that apparently was famous for stalling out during long left turns. After asking questions, I was advised that I should pick up a Carter AFB 3721-SB. I did, and had it installed.
Being new to this hobby, and to the Witchcraft of Carbureted Engines, I had a mechanic install the new carburetor. He told me that since the intake manifold of the 350 engine wasn't a direct fit, he used an adapter plate to make sure that it would work as it should.
It ran great after I picked it up until about 2 weeks ago. When I get into the car, on a cold start, it usually fires right up when I turn the key. But If I have driven it for a while, and have the engine up to temp, and then turn it off to go into a store; it takes it a long time to start when I turn the key. By "a long time", I mean 5 to 10 seconds of the engine turning over. It eventually starts up, but when it does, it runs rough for a bit, and then smooths back out.
I am a member of the Corvette Forum. I asked this question and was pretty much made to feel like an idiot because I apparently do not know how to ask the question correctly, and/or do not have 100% understanding of their questions to give them the exact answer that they were looking for. So I decided that I didn't feel like playing that game, and would stumble through it myself until I am able to figure it out. (I could always take the car back to the mechanic, but I want to learn).
One of the comments made, were that if I am using an AFB carburetor, I should also have a Baffle Plate (Stainless Steel), and Insulator spacer, and the Gasket(s). I was told that the insulator spacer if needed in order to guard against "Heat Sink", fuel "boil/peculation". I can see that.
I know that I have a (Stainless Steel Plate, and Gaskets, but I am not aware of an insulator spacer.
Can you please comment to let me know your thoughts, and correct part numbers that I should look for?
Thank you,
Michael
Charlotte, NC
Thank you,
Michael
Charlotte, NC
