'63 Ign. Switch - NCRS Discussion Boards
'63 Ign. Switch
  • Loren L.
    • April 30, 1976
    • 4104
    '63 Ign. Switch
    Is the 1116636 1963 ignition switch actually marked "636" on the case? Thanks.
  • Harry S.
    • July 31, 2002
    • 5258
    Re: '63 Ign. Switch
    Loren, I do believe it's a 635 switch and it is marked on the case.
    • Michael G.
      • November 12, 2008
      • 2155
      Re: '63 Ign. Switch
      Here's one with "635" on it...
      • Loren L.
        • April 30, 1976
        • 4104
        Re: '63 Ign. Switch
        Thanks guys. Google's letting me down - won't tell me what a 1116636 is for ........
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          Re: '63 Ign. Switch
          Loren, According to this link it was superceded to 1116647.
          This link shows that part for 1963 Buick "ALL".
          • Loren L.
            • April 30, 1976
            • 4104
            Re: '63 Ign. Switch
            Thanks, Rich. That means that "at some time", 1116636 was in the "line of succession" for a '63 Corvette ignition switch, because this one came out of a ONE FAMILY OWNED '63 Blk/Blk FI coupe. I'm trying to provide answers to a local restorer.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11302
              Re: '63 Ign. Switch
              Loren, I searched a bit more to see if they're functionally equivalent. They are.
              gmpartswiki has photos but the part is marked "647" with a GM box marked 1116636. Note the terminal pinout below.
              More searches tell me that the 1116635 was superceded to 1116650 (D-1449)
              A 1116635 switch (below)appears to have the same terminal pin configuration as the 1116636/1116647, however, it is missing the IGN2 terminal which is on the 1116636/1116647.
              Obviously on that car, the Ignition switch harness plug fits onto the 1116636 switch and it should function properly. The IGN 2 terminal is not used in the Corvette harness.
