Question regarding the depth of the "slot" at the one end of replacement / repro trailing arm shims.
Is the base of the slot, the "U" at the bottom of the slot, the same distance from the edge of the shim as the base of the hole on an OEM '64 shim? In other words, are the slots cut deeper or longer into the shim than the position of the hole in an un-slotted shim?
I have a bunch of non slotted shims (2 holes). I need to have an alignment. I am wonder if I can just cut "slots" into one end of the shims instead of buying a set of slotted shims for $50 plus shipping. If the slot length or depth is the same as the hole placement I see no reason to not cut them at one end.
It is hard to tell for sure but.... looking at pictures of shims on vendor websites, the "slots" seem deeper or longer than the position of the holes.
