Any way to distinguish a china made ignition coil from a genuine nos - NCRS Discussion Boards
  • Joseph C.
    • June 10, 2012
    • 17
    Is there any way to distinguish a China made reproduction 1115202 ignition coil from a genuine Delco Remy NOS coil? Thanks, Duke
  • Harry S.
    • July 31, 2002
    • 5258
    Re: Any way to distinguish a china made ignition coil from a genuine nos
    1) What did the packaging look like
    2) Are the posts magnetic?
    Post some pics
    • Joseph C.
      • June 10, 2012
      • 17
      • Harry S.
        • July 31, 2002
        • 5258
        The original posts were steel and magnetic, most of the reproductions are stainless steel and are non-magnetic.
        • Leif A.
          • August 31, 1997
          • 3607
          This may be the best way...they can't even get the "+" and "-" poles on the correct side. My recommendation would be to call David Sokilowski and buy a NOS from him. That's what I did...a few more $$$ than the repro but worth every cent.
          Leif
          • Gene M.
            • April 1, 1985
            • 4232
            You could observe one of these two situations:
            With the China made reproduction 1115202 ignition coil your engine will not run.
            With a genuine Delco Remy NOS 202 coil your engine will run.
            • Stewart L.
              • March 1, 1980
              • 351
              Metric threads on Chinese vs std thread on original Delco.
              • Frank D.
                • December 27, 2007
                • 2703
                My experience with repro coils is not stellar -- at all.
                To test them I throw them in the lake behind my house....if they sink they're bad, if they float, they're good...
                As a generic back-up or troubleshooting part the NAPA Echlin IC-12 will do in a pinch...
                • Dave S.
                  • August 31, 1992
                  • 2918
                  If you need an #087 or #202, originals are extremely easy to obtain in NOS or used condition for reasonable prices. There is no need to buy an offshore Delco look alike reproduction. Used coils are a good choice if tested on a running car and brought to operating temperature. Properly cosmetically restored they will judge and operate perfectly. If you need rarer colis like #263, #210, #231, #272 etc. then that is a different story. Those are production line only and are quite scarce.
                  • Gary J.
                    • April 1, 1980
                    • 1229
                    Gene you are spot on, you are just stating the obvious.
                    • Gene M.
                      • April 1, 1985
                      • 4232
                      Yes and sometimes it’s fun........
                      • Joseph C.
                        • June 10, 2012
                        • 17
                        • Darryl D.
                          • February 7, 2017
                          • 386
                          [QUOTE=Dave Strickland (21448);856939]If you need an #087 or #202, originals are extremely easy to obtain in NOS or used condition for reasonable prices. There is no need to buy an offshore Delco look alike reproduction. Used coils are a good choice if tested on a running car and brought to operating temperature. Properly cosmetically restored they will judge and operate perfectly. If you need rarer colis like #263, #210, #231, #272 etc. then that is a different story. Those are production line only and are quite scarce.[/QUOTE]
                          Where can these be purchased?
                          • Leif A.
                            • August 31, 1997
                            • 3607
                            Where can these be purchased?[/QUOTE]
                            Read post #4...for one outlet.
                            Leif
                            • Larry M.
                              • January 1, 1992
                              • 2688
                              Dave Strickland may have a few for sale. Or call David S in California.......his phone number is in the Driveline. Ebay is another source. Or simply put an ad in the Driveline or over at Corvette Forum C2 WTB website.
                              There are MANY MANY places to buy if you check around.
                              Larry
