Initial 4150 Holley Carb Choke Set-up - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2640
  • Jimmy G.
    • November 1, 1979
    • 975
    Re: Initial 4150 Holley Carb Choke Set-up
    As long as you have the inside spring installed correctly, the starting position should be mid point. After a couple of cold starts (and I mean COLD) it can be adjusted to close the choke to a full position (which I do not do by the way - only 90% or so) Being in SC full set is not needed. Once this is set to your satisfaction, then set the high idle
    • James W.
      • December 1, 1990
      • 2640
