1970 Corvette LT1/ZR1 hood stripes if you have a correct before 15,9xx - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 670
    Does anyone have these demensions from side of hood to stripes and from hood hardware to fron of stripes? the kit i reseived looks off by a lot!!!
  • Ronald R.
    • May 31, 1989
    • 670
    1970 Corvette LT1/ZR1 hood stripes if you have a correct bafore 15,9xx
    check these dimensions please and let me know if OK RDR
    2 and 3 are from indent for hood trim, 1-4 from side of hood
    • Ron G.
      • December 1, 1984
      • 865
      Re: 1970 Corvette LT1/ZR1 hood stripes if you have a correct bafore 15,9xx
      Ron,
      Do you have first design or second design hood stripes? If you have second design? I have every single dimension from the top of the hood to the bottom and from side to side. Thanks and please advise. - Ron
      "SOLID LIFTERS MATTER"
      • Patrick B.
        • August 31, 1985
        • 1986
        Ronnie--- My LT-1 is vin #14297 with a July 3 body build date and the stripes are the original factory applied stripes. Your pictures are a bit confusing about where on the hood you need measurements. I attached a picture of the one place I was sure of. The end of the stripe on the driver's side is 9 3/16" from the edge as opposed to the 8" in your photo. The passenger side measurement was 9 1/16" so the factory was not super careful. If you can post an overall picture of your hood with tape to mark the measurements you need, I will make them for you.
        I don't know why the overall picture of my hood turned sideways when I downloaded it?
        Disregard the amber turn signal lenses, the car is a 70 not a 71. I just liked the amber lenses and clear bulbs.
        • Ron G.
          • December 1, 1984
          • 865
          • Ronald R.
            • May 31, 1989
            • 670
            one of the last of the first design, 155XX
            thanks RDR
            • Ronald R.
              • May 31, 1989
              • 670
              Pat if you can give me the point near the wind shield end to edge of hood, and end of point to sides of the hood. In the front of hood the widest point and distance from the chrome trim recess to the stripe at both ends of the trim recess in hood. Or simply put some dimensions on a picture. I think mike is correct but just want to be sure! thanks Ronnie
              • Gary B.
                • July 31, 1979
                • 926
                Ronald, this is from 70 s/n 145xx. Uneven hood stripe. I have known this car since the early 70's and have owned it since 1980. I know the paint and stripe is original.
                I'll post several pictures in a few threads.
                Gary Bosselman
                • Gary B.
                  • July 31, 1979
                  • 926
                  • Gary B.
                    • July 31, 1979
                    • 926
                    Second picture is the front of the hood, edge of the chrome to the first stripe.
                    Gary B
                    • Gary B.
                      • July 31, 1979
                      • 926
                      Front edge of the hood to the bottom Stripe.
                      • Gary B.
                        • July 31, 1979
                        • 926
                        Original stripes will come into the 12th opening of vent grille. Both side.
                        The LT-1 decal splits in half at the chrome bezel. The 1 is centered.
                        Gary B
                        • Gary B.
                          • July 31, 1979
                          • 926
                          Original stripes are not "Straight". They curve towards the rear. I don't think anybody makes the right early stripes. We'll have to live with the straight ones or do them by hand.
                          Gary B
                          Gary B
                          • Gary B.
                            • July 31, 1979
                            • 926
                            71 stripes are the same dimensions. This is an original paint 71, fairly early car. Note the stripe also points to the 12th vent opening from the end. 71 and 72 stripes are more straight, not curved.
                            Hope this helps.
                            Gary Bosselman
                            • Ronald R.
                              • May 31, 1989
                              • 670
                              yes first design
