I have tried to adjust my Driver side dual air control to allow the temp to be 70 degrees. The passenger side will yield cold (60ish) air but the driver side is around 80 degree air. Has anyone had trouble with their C5 dual air system ?
Problem with Dual Air on C5
Re: Problem with Dual Air on C5
Gene there are mode motors that open and close the temp. doors for each side. if you sit in car with the key on engine off and change the temp for cold to hot, you should hear the electric motors run for each side. it will have to be quiet to hear them work. GM does have issues at times with the internal motor gears stripping out.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Gene,
Any DTC set?
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
Thanks Joe Ray. I watched the Utube clip. I hope my little problem has been resolved when I pulled each AC fuse individually a few days ago. I drove my car this past Saturday to a club event and probably put 100 miles on the car. I had cool air on each side.- Top
