My car sat for some time but always had a mix of ethanol free and race gas in it. The rear float valve was leaking so I replaced both (very clean in the bowls) changed the power valve per specs and the accel pump
It is very rough at idle 800 and varies 200 rpm high and low. Cruising the highway at low speed it like riding a bucking horse. Give it a little gas or floor it and it runs like a 365 should.
Initial timing is set to 10 and vacuum advance brings it to about 25 degrees. Checked vacuum hoses, checked for vacuum leaks on the intake and carb using brake fluid and all ok. new points rotor and cap. choke ok
Do I just have a carb issue or could it be something else?
