Is there a good match for the argent silver green?
I found this
DDL #8568
I found this
(thin 50% with thinner).
PPG Delstar (catalyzed enamel)
(Mix 8:6:1 Delstar/DTR601 Reducer/DXR80 Catalyst):
DAR #8568PPG Delstar (catalyzed enamel)
Mixing Formula (1 qt):
DMR 433 416 units
DMR 435 420 units
DXR 495 20 units
DMR 499 160 units
If you want to prime the wheels first, I recommend using PPG DP40LF Epoxy Primer mixed 2:1 with DP402LF Catalyst. This will give you a bullet-proof finish.
The BACK side of the steel GM Rally Wheels and the rim/bead area was not painted silver. Rather, the entire back of the wheel and the bead area was painted an odd light grey color (I have heard some were black, but I've never seen an original wheel that was black on the back side - all old wheels I've been able to recover have been this grey color). This color is perfectly matched with the following Delstar mixing formula. This is the tip-top finishing touch for a set of perfectly restored Rally Wheels:
Mixing Formula (1 qt) (cumulative units)
DMR 475 6
DMR 490 106
DMR 400 272
DMR 487 442
DMR 415 447
DMR 476 457
DMR 491 477
DXR 495 497
DMR 499 1000
Mix the Delstar 8:6:1 Delstar/DTR601 Reducer/DXR80 Catalyst and shoot it with a paint gun.
thanks RDR
DMR 433 416 units
DMR 435 420 units
DXR 495 20 units
DMR 499 160 units
DMR 475 6
DMR 490 106
DMR 400 272
DMR 487 442
DMR 415 447
DMR 476 457
DMR 491 477
DXR 495 497
DMR 499 1000
