1970 ZR1 Corvette speedometer gear reduction unit with 411 rear end. Anyone seen one of these? I had a L88 that had one, my ZR1 does not have one, thanks RDR
1970 ZR1 LOOKING for rare part
Re: 1970 ZR1 LOOKING for rare part
Not hard to find a picture. Google is your friend:
See the Stewart Warner item. Also the one for Camaro.
BTW: The same gear reduction unit was used on any Corvette with 4:11 gears. I would think a similar unit was used in other GM vehicles with 4:11 gears. I know the same looking unit (with different internal gears) was used for 4:56 rear end. If there are any speedometer correction shops left in the world they likely have a drawer full of them and the internal gears to adjust the speedometer for accuracy.Terry- Top
terry: u imply the gear reduction units were commonly used on corvettes. i've never seen one on a c-1 or c-2 although i acquired one in the Don Blatchley stash i received in the late 70's(u will recall ole doc bletchley bought grady davis's year old corvettes and ran them in scca. ) don had a 62, a 63, a 66 and lastly a 69. perhaps the gear unit was born with the 69. enlighten me regarding the usage of these units. thanks, mike- Top
Go to a HD truck salvage yard that has older trucks. They were used on many makes. If you find one and the ratio is wrong, I have a complete selection of gears and shafts. Just need to know the ratio you needDick Whittington- Top
Is this the style? thanks RDRAttached Files- Top
or possible one of these? Or does anyone really lnow? thanks RDRAttached Files- Top
You know I know nothing of C1s or C2s. I don't even think of those when I answer here, but I guess I should limit my comments. Time to pack anyway; and stop this foolishness.
We see them on the chrome bumper C3s with those deep axle ratios I mentioned. It wouldn't surprise me to see them on other Muncie so equipped Corvettes, but I plead ignorance.Terry- Top
According to GM the correct speedometer adapter for your application is NO ADAPTER. An adapter was not used for 1970 Corvettes with 4.11:1 axle ratio. Your application used a speedometer DRIVE gear of GM #3924097 and DRIVEN gear GM #3860348. The latter is a 25 tooth gear and orange color-coded. The 3924097 DRIVE gear was replaced by GM #6261795 in March, 1975. The latter was discontinued without supercession in March, 1999. The 3860348 DRIVEN gear was discontinued without supercession several years ago. I believe that replacements for both gears are available in the aftermarket.
If you had a 1971-72 ZR-1 with 4.11:1 rear gear ratio then different speedometer gears would have been used in conjunction with a speedometer adapter.
1967-69 Corvettes with 4.56:1 or 4.88:1 rear gear ratio did use a speedometer adapter. 1967-69 Corvettes with 4.11:1 rear gear ratios did not use an adapter.In Appreciation of John Hinckley- Top
